q4 tps question
  • q4 tps question
    i am using a 95 z24 2.3 throttle body on my 3500. i have a 660 tps on the tb but its throwin a tps code and idles kinda crazy. i was wondering if i should be uing a q4 tps? the pcm shows the tps at 46% at idle? is that high? should it be at 0%? like the Q4 reads from a diffrent spot?
    You make sure you installed the tps correctly? It doesn't matter which tps you use.
      yea its installed right the little dowel is in the whole in the tb. i was just wodern if it was strange that the sener shows 46% at idle? is that the way its suposed to be?
        You can install it with it all lined up correctly on the outside, but the inner rotator that touches tb shaft can be clocked out a few degrees. It should not be reading 46%.
