I'm not clear on whether this engine came with your car or not but if it did you may end up with less or mediocre performance improvement. The intake valve optimizes low end torque and combustion efficiency when closed and high end HP when opened according to GM. The slot in the throat of the intake may seem like a useless aberration but a lot of people ground the fin in the cast iron head down before they found out it was responsible for a ~17% increase in flow ability.
The remark about performance has more to do with the cam than the intake. The LSA has a lot to do with the cam being able to provide proper variation in the power curve. By having the cam reground to a tighter LSA you will also need to limit the cams variation otherwise it will be retarded beyond what is optimum for the camshaft grind. Some fundamentals regarding that were discussed in a thread I linked to in the tech article section.
As long as you can fully tune those parameters you should be okay. I don't know all of the details as far as the precautions you have taken but just be aware if the cam is going to be fully VVT functional you need to be sure the increased lift and head shave is not going to permit interference.
And what's with the head studs and no turbo to exercise them properly.
