Titanium is very strong, but once it gets pushed past its limits, its strength starts to go down significantly. Case in point - Russian submarine hulls are made of titanium, therefore allowing them to dive significantly deeper than US submarines. But, once they start diving to extreme depths, the titanium starts to become brittle (as Aaron mentioned), therefore the depths that the submarine can dive to decreases. Each time they get close to the new max depth, the titanium weakens again, and the max depth once again decreases. Same idea can be applies to connecting rods. Once they start to stretch due to extreme RPMs, the peak RPM they can handle decreases or they will fail.
Titanium connecting rods forged aluminum pistons
Hey John! Glad you spoke up about your build.
Dave, he is using Gen 2 heads to get that kind of flow! He told me he cut a head inti sections and examined them.
Brad, he is making everything there at the school, the professor told me they had the rods left over from something else and John wants to machine them to fit the rod pins (they are 327 small journal).
We had a good chat on the phone yesterday, and told him you guys might be interested in what's being built.
Originally posted by ForcedFirebird View PostHey John! Glad you spoke up about your build.
Originally posted by 85maro View PostThe sides of the big & small ends contact the crank & piston Blackjack.
We were given some strict warnings on how to handle this plate when either bolting or torquing fasteners against its surfaces and other TI components... one which included the odd reality of how it readily galls and welds itself easily to other metal in friction contacts events... and the other was to NEVER let any kind of Chlorine Gas or Chlorine Bleach type chemicals get on the stuff....as it would readily corrode or dissolve this metal into Titanium Di-Oxide (which oddly now, I use in abundance as "Titanium White Oil Paint" when doing my landscape art). Other than that...the stuff was virtually bullet-proof. So my curiosity about how it can be lubricated conventionally stems form that experience.Last edited by 60dgrzbelow0; 11-19-2009, 09:59 AM.
flow numbers
28 inches of water
intake exhaust
lift flow
.050 34 21
.100 63 53
.150 80 75
.200 96 93
.250 114 105
.300 138 117
.350 144 128
.400 173 138
.450 196 148
.500 215 153
.550 228 159
I took a spare head that I had laying around and cut it into 8 pieces and you can not believe the how much fun cutting the heads up was, they give you an unprecedented view at what you can remove from the cylinder, exhaust is were I got the most gain.
The titanium rods are out of a small block Chevy 350 they have a 2.225 big end and .927 small ends; I am machining the rod thickness from .934 to the same thickness as the stock rods (.842). When I ordered the custom pistons I had the pin opened up to compensated for the .927 pin and I am going to run a full float pin. On the big eng I used a bearing to go from the 2.225 to the 2.000 rod journals. You can use any small block (5.700 with a 2.225 big end and .927 small end) Chevy rod, alls you need to do is machine the side thinner and put bushing in the small end to run a stock 3.1L .905 pin and set it up for press fit or full float either way it can be done.
Any metal pushed past it limit becomes weak steel, aluminum, titanium it does not matter what it is made of.
John, I didn't realize you used the 2.225" big ends! You realize that using those rods, you can more easily upgrade to the 3500 crank (steel forging)?
Either taking some off the rod end to compensate for the 2.249" rod dowel, or grinding the crank dowel to 2.225" would work.
Either way, I don't know if anybody has broken a crank or not (aside from negligence or oil failure), but the nodular iron seems to be holding for most.
Have you talked to your instructor about the trick I mentioned using an engine lathe to face the rods thinner? This will allow you to single point the titanium and not create too much heat across a large surface (ie hardening it).
Do you have the stock flow numbers for comparison sakes? As you know my bench as of now is being used for comparative testing more so than hard numbers and would be interested in your percent of increase at various lifts. Those numbers appear to be pretty linear over a stock set of flow numbers.
Originally posted by john52216 View Post28 inches of water
intake exhaust
lift flow
.050 34 21
.100 63 53
.150 80 75
.200 96 93
.250 114 105
.300 138 117
.350 144 128
.400 173 138
.450 196 148
.500 215 153
.550 228 159
On the exhaust side i have a bit more in the low lift, we're close at .4 lift and after that yours take off.
Here is the exhaust from a gen 2 head that i'm working on, i'm far from done though.
28" of water
.05 - 26
.10 - 55
.15 - 85
.20 - 107
.25 - 125
.30 - 135
.35 - 138
.40 - 139
.45 - 141
.50 - 142
.55 - 142
Good work man!
Now, what are your plans for the crummy gen2 lower intake?
Would you hack up the existing one and weld up stuff to it? The LIM covers more than just the intake ports... coolant, valley, valve train... makes it more of a PITA to make one from scratch..sigpicNew 2010 project (click image)
We will be building a custom lower for the Mustang project. It will all be designed in CAD, therefore all the parts will be able to be replicated at a later date. This will potentially allow for much more options for the 3x00 engines.-Brad-
Originally posted by IsaacHayes View PostWould you hack up the existing one and weld up stuff to it? The LIM covers more than just the intake ports... coolant, valley, valve train... makes it more of a PITA to make one from scratch..Lifting my front wheels, one jack at a time.
Originally posted by 60dgrzbelow0 View Post...and why is it that "Long Runners" allow the engine to develop more torque?
Scroll down to the intake manifold section.-Brad-
