Originally posted by 3400-95-Modified
View Post
high compression setup
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
Originally posted by john52216 View PostRunning those pistons with that gasket can be done but you will have to make valve relief cuts in the pistons which on assembly you can measure and then cut. You may loose a little bit of compression but it will add reliability to the engine build.
ill either do the piston flycuting like we talked about earlier in the thread or get some diamond pistons made with the reliefs already there.
another option was the .036 headgasket which would bring the quench down in the green and acceptable on the CR calc but would drive the CR up to something like 12.5.1Last edited by geldartb; 01-14-2010, 05:40 PM.sigpic
99 Grand Am GT
Originally posted by geldartb View Postanother option was the .036 headgasket which would bring the quench down in the green and acceptable on the CR calc but would drive the CR up to something like 12.5.1-60v6's 2nd Jon M.
Originally posted by rooster5333 View Posttry looking at a truck stop for a small ceramic heater that plugs into cig ltr plug. If you have an old enuf car that has cig ltr that is. they are small and sit on the dash to help keep your w/s defogged. trucks are not well designed most of the time. and they cant put glowing element stlye units inside the cabs. once u can see, just unplug and remove so it dont fly around during your heavy throttle romp to work.I actually have thought of getting one of those.
Joseph, my stock 3100 thermostat has a 2nd thing on the end which closes off a path in the LIM, which does what you described I believe. I tried a 180F stat once in summer, but those that fit that are not the stock 195F lack the extra piece on the end which seals up the other passage when it's closed........
But maybe it doesn't function that way... I'd have to think about it and it's late... LOLsigpicNew 2010 project (click image)
Originally posted by pocket-rocket View PostYou say that like 12.5:1 would be a bad thing. I would love to have some way of a direct bolt in way to get 12.5:1 in my car without going custom, lol. I'm glad joelbob researched the whole thing with the N* pistons and stuff. I wouldn't mind following the same path to bump up my CR.
im not against either option. ill most likely go with it one way or another but not till next year, i want to see what the car as it sits now does.sigpic
99 Grand Am GT
I can't recall if the dude with the 12.5:1 compression motor had posted the cam specs or not. Ben do you recall what they were? (the guy with 3400 with 3.4 pistons). For those of us with 3500 heads we can use the MLS to bring it to the same compression yet good quench so that seems like a great combo depending on how much cam we have to run...sigpicNew 2010 project (click image)
Originally posted by geldartb View Posthaha no its not a bad thing. this would require me getting a bigger cam probably. ill have to us Ben's service to see which would benefit more or which would would best. the cam i have now or a bigger one.
im not against either option. ill most likely go with it one way or another but not till next year, i want to see what the car as it sits now does.-60v6's 2nd Jon M.
Originally posted by pocket-rocket View PostYeah, after getting all that trouble you had sorted out it would be a waste not to see how she does now. I didn't ever read what the issue was with the noise, what was it?
so i just re-timed the chain and gears and i think i torqued the cam gear to 106ft-lbs put it all back together started it up and it was uber quiet in that area.
you dont even know how happy i was when i started it up and it was quiet.
i tried an outing at the track but it seems my ICM was junk. it would cruise around town fine but when you nailed the gas it would just sputter like crazy. once i swapped that out it ran awesome. unfortunately i never made it back to the track and without a wideband it was probably a good thing.
right now im happy with the performance and i know with a good tune it will get better. but you know there is always that itch for more.
Originally posted by IsaacHayes View PostI can't recall if the dude with the 12.5:1 compression motor had posted the cam specs or not. Ben do you recall what they were? (the guy with 3400 with 3.4 pistons). For those of us with 3500 heads we can use the MLS to bring it to the same compression yet good quench so that seems like a great combo depending on how much cam we have to run...Last edited by geldartb; 01-15-2010, 02:37 PM.sigpic
99 Grand Am GT
Impressive 12.1 compression is nice. I would like to ask how your acheiving this?... What is your motor setup internals and all.
With what I am doing I hope to gain 11 or perhaps as close to 12 as I can get, this is my setup that Ben recomended.
Head gasket set
head bolts
street/strip heads
street/strip manifold set
65mm TB w coolant bypass
forged 10.5:1 pistons with rings
strip camshaft
custom length pushrodsLast edited by Classick Century Custom; 01-17-2010, 03:55 PM. Reason: forgot to add a few things sorryROCKABILLY KLASSICK HOT RODS AND KUSTOMS
