w...t... f...
high compression setup
Gotta use a junk head and modify it to work properly.
Generation III Internal Engine - Piston Flycutting in engine / car - KEYWORDS added: piston flycutting flycut notch notching PTV clearance MS4 PRC stg. 2.5 5.3l Texas Speed Lindy Tool DIY instructions tutorial The idea here it to cut reliefs into the piston to obtain adaquate piston to valve (PTV) clearance. The tools...sigpic New 2010 project (click image)
Well, as that thread shows, spinning a bit/valve could mess up the valve guides, and also if you look at the thread he had to grind the hell out of the valve seats so the cutters would sit right.sigpic New 2010 project (click image)
well even if it required using a junk head i still got the heads off my old 3400 and the pistons are currently mounted in that block so none of this would get done on the engine in the car, just swap pistons when im done cutting them.
what im thinking would work right. the valves are in the same place, and i could build a setup out of sheet metal or something the same thickness of the headgasket ill be using to do this.
pretty good writeup from LS1tech. the guy seems like he did his homework on that.
got any links for the stick on types. i found the lindy tools site and its $75 for the cutter and 25 for the guide rod.
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
Why do you think you need to cut reliefs for your valves? Or are you wanting to do that to lower compression??? Dave is the one who needs to cut reliefs due to his long duration...sigpic New 2010 project (click image)
flycutting would not change CR much at all. it would help, but at that point you could just get the pistons machined for a better overall look/design. If you run a larger cam with more duration and such, then i would def flycut first if you still want to use stock pistons. otherwise the diamonds can be ordered with valve reliefs already.
those are pretty neat, never thought about doing it that way.
Rotating the valves in the head won't ruin anything. How do you think valves have been lapped since the dawn of re-seating valves? Even a valve seat machine has a pilot that goes into the guide to keep the facing of the seats accurate
You have to figure if you do a valve relief, you are going to lose about 2-5cc's of material depending on the depth of cut, but how safe is the ring lands going to remain on the already thin castings after valve reliefs are cut?
Off topic, but an easy way to know if your valve seats and valves are concentric is to spray the valve with some runny lube and drop them in the guides - if they hit the seat and bounce, they are good, if they thud, you need to recondition either the valve angle or the seat sealing angle.
Originally posted by IsaacHayes View PostBradon, what is your intake valve closing ABDC ? I'm wondering what the 12.52:1 compression will be actual with your cam.
IVO 6 BTDC
IVC 42 ABDC
EVO 53 BBDC
EVC 1 ATDCsigpic
99 Grand Am GT
That's not enough to run 12.53:1 compression. That won't bleed it off enough IMO. With .070 quench and 11.51:1 though you'd be fine though. I have 33 IVC and I'm going to shoot for 91 octane as that's all we have. It ran ok on 93.sigpic New 2010 project (click image)
