borrowed this from my post in another forum topic.
ok so lets say i go with the 3.4 ironhead piston and a 3500 MLS head-gasket with a thickness of .035 and get a CR of 12.52.1 with an ideal quench of 0.045 ill be good right. i already picked up the piston way back when i first swapped the newer 3400 in.
so trying the 3400 head-gasket bore of 3.75 vs the 3.80 of the 3500 it brings a 12.56.1 CR not much of a difference there and it doesnt affect the quench. ok so the MLS gaskets are actually a 3.72 bore for the 3500 but still that only brings it up to 12.58.1. ive been playing around with this for awhile and never got a positive answer from anyone on waht would work without problems.
ok if this will work without giving me problems and by problems i mean valve to piston contact and other ill effects. this setup would give my cam the high compression it wants and would make it perform nicely and keep me from buying a different cam with all those new profiles available.
just picking you guy's brains to get some plans together.
