What about an acura NSX trans? I think Archie adapted one of those to something once in a fiero... That might be a trans behind a high revver, but then again it was behind a V6 so maybe not.
has anyone made a 3000?
Originally posted by IsaacHayes View PostWhat about an acura NSX trans? I think Archie adapted one of those to something once in a fiero... That might be a trans behind a high revver, but then again it was behind a V6 so maybe not.
Would the motor build work? could you mix and match
part to make it work?
3.4 block
2.8 crank
3x00 top-end
iron block 3.4 pistons?
??? rods
I don't know enough about it to know what would be the right parts
but it would be cool to see built..sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
iron block 3.4 pistons would not work. The rods are all the same, it's the pistons that would have to be custom for the 2.8 crank and 3.4l bore. Might as well get them high compression because shorter stroke makes it easier to run higher compression without pre-ignition because the speed of the piston is less which means less heat...
If going all out I'd do:
3400 block.
3500 heads
2.8 crank & rods
custom pistons, 12:1 or so
rowdy ass cam...sigpicNew 2010 project (click image)
Originally posted by IsaacHayes View Postiron block 3.4 pistons would not work. The rods are all the same, it's the pistons that would have to be custom for the 2.8 crank and 3.4l bore. Might as well get them high compression because shorter stroke makes it easier to run higher compression without pre-ignition because the speed of the piston is less which means less heat...
3400 block.
3500 heads
2.8 crank & rods
rowdy ass cam...
The crank is the issue. Where the rod height is in the piston needs to be made like the 2.8 pistons...sigpicNew 2010 project (click image)
