Originally posted by robertisaar
View Post
Project: L-body headers
They look great John! Really close to equal length, should perform great!
What color are you coating them? Silver/aluminum color would be cool. (black won't show them off as much)sigpicNew 2010 project (click image)
Originally posted by ForcedFirebird View PostGrand Am coming soon. The j-bodies were lacking and didn't take advantage of the three beta sets, so once the 2 of those are finished we will be moving on to other body styles
doing great work. so glad to see someone who is finally in it for the better of the community and not just themselves. even though i know you have to try to makle a *little* money out of these.
Cammed 3400 --> 224whp 210wtq
Cammed 3500 --> ???
1 of 5 3500 J-Bodies
I was surprised the L body sets sold out as fast as they did. Well I bought the first one, and expected the others to sit for a while while people saved up... The people with active project build ups recently had already obtained S&S headers, so I was wondering who else would be getting them.sigpicNew 2010 project (click image)
Originally posted by lolwut View Postcan't remember what my reason for getting them was, but I'm glad I did.-60v6's 2nd Jon M.
Alan, even on a gen2 motor, they have to help a ton! Our manifolds really stink! I bet your car can keep up with or beat a stock 3100 car now. I've wanted headers on my car ever since I got it. Too bad I don't have the cash to put a set on both Berettas!!sigpicNew 2010 project (click image)
Originally posted by ForcedFirebird View PostDon't forget Alan also got the full mandrel-bent exhaust
Since he got the actual prototype headers, he got a great deal on the exhaust as well
Issac, the headers do wonders, especially in the mid-range and higher on this engine, which is a damn good thing with the 3t40's gearing. Once I have the intakes on this thing and a chip it might be able to keep up with traffic!
Not sure if here would be the best place to post them, but have a second gear pull and some mindless revs.
Alan
Timing belts/chains > me
1992 Beretta GT
The gen2 needs help up top (due to the intake manifolds), so that's cool that it helped you in that area. I need to get a clip of my exhaust, I think my camera records low frequencies well and it doesn't get over loaded so I need to get some clips going for future comparisons.sigpicNew 2010 project (click image)
Originally posted by IsaacHayes View PostWhat had to be adjusted on his? Just curious.Originally posted by ForcedFirebird View PostFront went in with the engine in it's normal position once the intake tube and radiator hose was pulled (and of course the coil packs), it was all the rear that will give you the fight.
In fact, it was so tight back there, I had to modify the rear header and make the adjustments on the jig...
THEN when the rear was all in and was bolting everything back up, the sway bar hit the extension I put on the collector (2.5" ID to hook to exhaust) and had to cut that off with a die grinder/cut off wheel inside the pipe! But one I got back to the just the collector, welded a 90* on.
So the production headers will more than likely have a bend on the end of the collector that's too long, so you can cut off what you need and put a slip-coupler on to continue to the back of the car (or have an exhaust shop weld etc).<- only in here to make the post over 4 characters long so it could be posted until I said this...
