I'm having an issue with my car in that it will run just fine at WOT (14.19 thru the exhaust) but in the shut down area the tach jumps up and down like hell and it's missing and stalling.
Takes several attempts to go from Neutral to Drive without stalling.
And while cruising home it's fine under load, but back off even a little and the missing and backfires start again. Put it neutral, rev it, and it will clear and I can put it back in gear and continue driving.
NO CODES!
Pulled the UIM, injectors test good with the meter.
Oil pressure good as ever.
Looking for ideas!
Thanx
NO CODES!
Looking for ideas!
Thanx
