I was given a 86 jeep cherokee with a locked up motor but fairly new transmission and transfer case so i decided to take another 2.8 i had laying around that came from a 85 S-10 pulled it apart and found it was super sludged up and had pretty bad cylinder wear. so i took it to a local machine shop and they said it had to be bored .60 to clean up the cyl walls, when i removed the heads from the motor it had a few burned valves so i scrapped them and decided to use my 3.1 heads that have been ported polished and larger valves installed these heads have never been put on a motor.
so will my projected plans work and if so what else could yall give me for more power, also would anyone recommend me a camshaft, I'm gonna need all the power i can get to pull 35-12.50's
