When my Lumina was stock with the 3100 in it the torque converter would stall to about 2600-2700 rpm. Then I dropped the 3400 in there with a FAFB converter anticipating 3000-3200 stall speeds. When I saw 3700 rpm my jaw hit the floor.
Fast forward to today. Doing a highway pull while destroying a Honda the trans began a nasty slip shudder as I was going WOT in 4th. I lifted and have been babying it ever since. The trans is coming out in a week or two so I can stuff some Z-Pack clutches in it and do some mods to the valve body as well as install the 3.73 chain and sprockets. And finally fix my leaking axle seal.
My question is I'll be turboing this thing someday, and I want to pick the right converter for that while the trans is out. From what I've read, a turbo engine actually favors a lower stall speed, but I wanted to put it out there for those running a turbo with a 4T60-e
