Originally posted by Driver_10
View Post
I will agree that if you are setting up a loose motor you may need more flow. But with a 3900 pump already flowing more than a 3400 or 3500 pump I don't think a DOHC pump is necessary.
If you are going for 7500 RPM then a high pressure spring may be in order since the stock one will bypass at about 55 to 60 PSI. Running 7500 RPM will require pressure around 80 PSI (if you follow the 10 PSI/1000RPM rule) and I believe that even with a loose motor you will still only need a stock pump. But if you want to increase the volume then take small steps, don't just buy the biggest pump that will work.
