Since Im modifying my 3500 for oil-jets on all 6 cylinders, I was needing a pump with an adaquate flow rate.
After a lot of searching I believe that Ive found candidate for an oil-pump. The 3900 uses oil-jets stock so the pump will have the flow that I require. Here are some pics comparing the two...
Heres pics of the 3900 from the top (flange side)
Heres some pics of the 3500 from the same angle
Heres some pics of both from a side profile. Youll notice that the 3900 oilpump is a bit shorter. Im not sure how that will affect install on a 3500 block
And heres a couple more to compare pump size
