I plan on installing 3.1L heads on my 2.8L. Will it mess up the computer? Do I need to change anything else?
3.1L heads on a 2.8L
All the fuel injected iron heads are the same so it wont hurt a thing. Unless the 2.8 heads are screwed up you just as well save them and rebuild (port polish and all that good stuff) them for your 3.1.87 3.4 4x4 blazer
Originally posted by neo71665 View PostAll the fuel injected iron heads are the same so it wont hurt a thing. Unless the 2.8 heads are screwed up you just as well save them and rebuild (port polish and all that good stuff) them for your 3.1.
shark_bait:if you mean aluminum heads, its been done before since john(forcedfirebird) is using a 3.4(originally iron head) block with either 3400/3500 heads/intakes...
Originally posted by no_doz View Postthat is, if the 89 2.8's are TBI, im pretty sure they are but dont quote me on that.
Originally posted by robertisaar View Postright: all Iron heads are the same, but he didn't mention anything about using the 3.1 block, just the heads...
Right and wrong, The older carbed 60 degree iron heads had smaller valves, but yeah thats why I said all fuel injected iron heads.
He did mention it going into a camaro so I stepped out on a limb and guessed he was building a RWD setup and prolly going the simplest route and not building a hybrid.87 3.4 4x4 blazer
Originally posted by no_doz View Postif you want to use a 3.1 MPFI heads & topend, youll need to change the computer & modify the wiring harness a bit to go from TBI to MPFI.
I quoted you for integrity, and sorry, but the 89 2.8 has the same exact top end as a 3.1 - with the exception of the "2.8" badge in the middle of i the UIMThe only difference is that the 2.8 used a MAF ECM and the 3.1 got speed density.
And correct, all iron heads are identical after the 85-86 area when GM when to EFI.
wow i honestly thought the 2.8 firebirds/camaros were TBI, does this mean the 87+ 2.8 s10s were multi port fuel injected as well? if so thats great news for anyone wanting to do a 2.8 top-swap!
also you may want to check the CR calculator & see what compression you're going to end up with depending on what heads you go with.
either way though, everything ive heard has said to stay away from the iron heads in general if you are going to do a top swap, and you can quote me on that one :P
ah, thats where im getting that bullshit from then, i had one & my friends had a couple of the 2 wheel drive GMC ones from 90-92 & we always thought they were tbi but we never had to work on them so i never took much of a look at the motors.
i never really gave it a second thought but we almost never had to work on them...& thats kickass! lol
