Ok, I was able to find the other two as well. One is for a 4cyl, the other two are the 4.3 but I don't know what application.
Multiport vs TBI, and DIS conversion.
BHFM for the 2.2L is the only one with DIS, it has the inital spark advance set to 66 degrees.
Any other ideas why my DIS isn't working right? I'm so close! Other than the tendancy to die with the bypass opened, it's drivable.'98 Volvo V90 - Ford 5.0 swap in progress
I can get one, I was having trouble getting WinALDL to log on Windows
7, but it works if I run it as administrator. I never figured out how
to datalog with tunerpro.
Just for kicks, I tried my '7747 last night too. Behaves the same.'98 Volvo V90 - Ford 5.0 swap in progress
Yeah, WinALDL does the 7747/8062.
Line 970 was the closest it came to dying on this drive. When I clutched while coasting to a stop. Kind of gargled at for a second, log says 275 RPM. The only thing I did different was set the advance to 66 (based on the setting in the 2.2 bin), I had it at 60 before.Attached Files'98 Volvo V90 - Ford 5.0 swap in progress
Ooops, dup.'98 Volvo V90 - Ford 5.0 swap in progress
Yeah, it's tab delimited.'98 Volvo V90 - Ford 5.0 swap in progress
ok, looking at it, i see that the IAC opened up to 50 steps at that moment, next sample you're at 1225RPM with no change in throttle, or at least VERY little change. what BIN did you use to start with? and do you still have my e-mail address? if so, send your latest BIN and i'll see if i can find anything that looks funny...
I'm working off the stock Trooper bin, $42 AKHS.
I think I have your email, I'll dig it up.
I should also mention that most of that log is with the bypass open, should see the error flag when I changed that. I started with the bypass closed, but when I shift into third and above it knocks bad. So I shut it off and opened the bypass, that's when the knock count reset. Had some almost dying right after I started it, and when I was trying to get out of the snow bank I stopped in.'98 Volvo V90 - Ford 5.0 swap in progress
I am running $4E on the 1228062. I sent both files.
It doesn't seem to be dying and dipping as low as it was since I upped the advance to 66 (which actually retards the table, right?), but it seems I'm a little under on power. There's just a bit of highway by my house that I had been able to pull in 5th gear at 55-65, but I was slowly losing speed this time.'98 Volvo V90 - Ford 5.0 swap in progress
