I've been looking at what's needed to complete my engine. I'm having a lot of trouble making some descisions because I'm not farmiliar with how certain cam specs & compression ratios will affect engine performance/reliability/driveability etc.
Currently I have the following parts:
3400 Bottom End
3.4 Camaro RWD Pistons
Crank Scraper
3500 Top End
1615 Grind WOT Cam Specs: 280.6/283.8 duration seat to seat 225/227.6 duration .050" .603/.562" lift 111 ICL 111 LSA
Headers
26918 Valve Springs
LS1 Lifter Spring Mod
Megasquirt 2
For a car that will be used primarily on the street and possible become a daily driver will the 1615 cam be too much?? If it is used as a DD it will see some very cold weather. I've heard of great results with the 1617 grind. I'm not looking for help choosing a cam, just a little help to be pointed in the right direction. What it it exactly about my current cam that may not make it street/daily driver worthy?? What specs
With either cam will I have enough engine vacuum for my brakes at lower engine speeds? I really don't want to use an electric vaccum pump. What part of the cam specs gives me an indication as to how much vaccum it will have??
Should I use a 99- timing chain with the either cam or should I go for a single or double roller setup?? I'm trying to avoid the double roller since I don't want to machine my crank. Finding a reputable machine shop in Canada is not so easy and because they are few and far between their prices are astronimical.
With either cam what size throttle body & exhaust should I use? My current headers have a 2.5" collector but that can pretty easily be modified. My
I have also been looking into the Camaro 3.4 RWD head gasket to bump the compression ratio up to 12.35 I believe. I know I'm getting closer and closer to piston to valve clearance issues with the 1615 cam, probably not with the 1617 but that aside, is this too much compression for a street motor running on 91 octane?
Thanks in advance..
3400 Bottom End
Crank Scraper
3500 Top End
Headers
26918 Valve Springs
Megasquirt 2
Thanks in advance..
