Well its time for a question. First off, I need to replace my LIM gaskets as well as my valve cover gaskets, but here is the thing......my car has 245500 miles on it and doesnt burn any oil and doesnt have a tap to be heard. With that said while I'm down as far as the lifter valley why not go ahead and change the cam bearings, lifters and camshaft?.......245k mi is alot of miles for a stock cam and I KNOW it has to have some wear.
So here is the question......What would be the recommended cam for my bone stock 3.4L? I dont mind a lopey idle as long as tuning is not involved (it would be a hassle to have to tune a OBD1.5 car or even convert it to OBD1) I would rather not go back with a stock cam. The timing set is brand new so that is one thing that i will not have to replace. Pushrods and rockers should still be fine unless a cam swap will require them to be changed (which I would rather not have to do)
So let me have it guys voice your opinions.
 ). The 252 and 260 both will run fine on the stock tune even with 1.6 rockers, but will benefit from tuning.
  and if I tried to use a 95 tranny the transmission will burn itself up, most likely due to the pcm controlling the line pressure and the wiring being a little different. You know, this has gone a bit off subject, but this is good info, and why in the heck didnt they just leave everything the same between 94 and 95? Do you guys know how hard it is to find a year specific tranny in local junkyards? That was a pain in the ass!
