The damper will seat against the timing gear, you could use it to press on the gear. I am not a fan of using the bolt as a press. They make tools for that. If you get a short piece of pipe you can use that with a damper install tool to seat the timing gear
Timing Cover and Timing Chain
Well I have the external timing setup from the WOT store, which includes a different bolt so I won't be using that to put it on. I guess if I can't manage to grease it up and slide it off/on there I will be back
It looks like my parts will be here on Friday so I am probably going to do it this weekend. Any other tips? Last time I did this I was able to move the cam freely and I had to align the dots when putting it together. But now with the motor together and the valve train in place the cam nor crank should move on me so I don't have to turn anything by hand to align correct?
Thanks!SpudFiles
Theopia
Enjoy life online.
They can and might move a little... so be prepared to put a wrench on the cam nut to move it a bit... Also the crank will spin free untill the piston comes in contact with a valve if any are open far enough.
So I should probably just plan on having to realign the crank and cam? There should be no harm in moving things to get the dots aligned?
Thanks.SpudFiles
Theopia
Enjoy life online.
Yup. If you do have to spin things, pull the valve covers and loosen the rocker arm nuts so the valves close and there is no pressure on the cam. If you spin things without the crank and cam in sync the pistons could hit the valves as previously stated.sigpicNew 2010 project (click image)
Thanks guys. Damn parts didn't come this weekend... FedEx updated late Friday afternoon (when it said they were to be delivered) and said they had JUST shipped! Now they say Tuesday... ugh...!
Do you guys think pulling the front block coolant plug and draining as much coolant that comes from it will be enough to stop coolant from pouring out of the timing cover when I pull it off?
I remember when I put my crank pulley on, it was a HUGE pain... had to use a mallet and a block of wood to get it to slide on. Is there a proper installer tool or should I just lube it up again and knock it with more wood?
Thanks.SpudFiles
Theopia
Enjoy life online.
Whoa wait, you hammered on the crank pulley???? BAD idea!!! Hope your crank and bearings are ok from that... Mine I just used the bolt and it drew it up...
Coolant plug, give it a shot. It's gotta be better than when I just drained the radiator on mine, and coolant spilled into the oil pan some. (I let it set overnight then pulled the oil plug until only oil came out). Then changed the oil after letting it run for a minute or two.sigpicNew 2010 project (click image)
Well it's not like I beat the shit out of the pulley, I tried to be as careful and gentle as I could but yes it was damn near impossible to get the 3100 pulley onto the 3500. It's as if it was made a slightly different size.SpudFiles
Theopia
Enjoy life online.
OK where in the HELL is the front coolant plug? I've taken out everything that I THOUGHT was it and they are all dry. The GM manual says for the 3100 it's in between the starter and oil filter. That's a screw hole with a bottom in it on my 3500!!
Also, since the 99 crank sprocket is thicker than the 3500, that isn't going to cause problems when I try to put my external trigger back onto the end of the crank will it?
Thanks.Last edited by PCGUY112887; 07-29-2009, 09:16 PM.SpudFiles
Theopia
Enjoy life online.
Originally posted by 1988GTU View PostWhy not just remove the bolt that protrudes into the cooling gallery?
And I am so dumb I found the front plug... I had to look in a picture of a motor on a stand before I could go find it myself! Found it now...Last edited by PCGUY112887; 07-29-2009, 10:07 PM.SpudFiles
Theopia
Enjoy life online.
The front chain gear is not thicker, the chain is thicker so the teeth are thicker... the overall thickness of the sprocket itself has NOT changed... these parts are 100% interchangable... Superdave is running it.
Well day 2 of this stupid project, and I am stuck on getting the new crank sprocket on. Damn thing just go on! Old one pulled off like nothing, oiled up the crank and inside of the new one and it went nearly all of the way by hand and now it's stuck! Tried tapping with a pipe but it's a plastic pipe (only thing I have big enough) and it won't go anymore with it. Can't pull it back off by hand either... it's on tight! Either I am going to have to find a metal pipe to put on there to hit, or try to use the installer and use the balancer to put it on but I really don't want to put the pulley back on then take it back off!
Is the crank bolt an M12 x 1.5? The bolt that came with the TCE external trigger is fairly torn up and there are some flakes in the crank bolt hole from it. I want to get a new bolt and clean out crank threads and I may need to chase them with a tap or a bolt or something...
I swear I always run into problems!!!Last edited by PCGUY112887; 07-30-2009, 09:33 PM.SpudFiles
Theopia
Enjoy life online.
This is not a problem, this is HOW IT IS DESIGNED... Go get TWO proper tools. A metal pipe the diameter of the sprocket... Cut the pipe down and put a large enough washer on the crank bolt so you can PRESS the sprocket into place using the pipe as the press. The second tool is a gear puller if you wish to remove the sprocket again. You will NOT be able to remove the 99 and older sprockets by hand.
And yes the crank bolt is M12x1.5
