No there is nothing done to this block, the bottom end is still 100% GM built from the factory... Its a 05 3400 short block. The only thing I've done was replaced the cam bearings after 15k with the Milzy motorsports cam. I bought the engine with 4k and did 15k before this cam, and I think I've put about 12k on this current setup. Car had 74k on it when I bought it, the OD now reads 86 or 88 IIRC. And no, the crank bearings would never be worn that bad and not show signs of disaster such as oil more metallic than my paint, and uber low oil pressure.
And IIRC as you noted with the roller chains, the nature of those to begin with and how they work, they can have a much tighter setup, where with how mine is designed they do need a little slack, otherwise it would destroy the gears/or bind up the setup.
It's alive.
I hate how the camera emphasizes all the tiny exhaust leaks and the little ting you get with headers anyways... BUT honest to god, after I did the lifters I still heard tapping as you would call it, and I thought it was just the nature of the cam, BUT since I've now done the chain the engine is as quite as it was when I first fired off this build. I'm much happier now. You could hear a chatter as you would be driving before, and when ever I pulled it in the garage at the end of the day... All those noises are now gone. I love it.
No oil leaks either... That's amazing in itself.
It's alive.
