Headgaskets
  • #16
    Yeps I have the ARP heads studs
    • #17
      hahah m well only one way to find out again what happened. Disassemble it again
      • #18
        Originally posted by TurboAlero View Post
        12 A/F wide band
        That seems lean for being boosted. I guess as long as you has no knock you're fine though....
        • #19
          i thought the same thing... i run 12.5:1 N/A...
          • #20
            You could always have a set of MLS gaskets made.... not the cheapest option but it would probably be the best.
            2000 Grand Am GT
            2011 Chevy Impala
            • #21
              Will MLS put a good "fire" ring in the gasket or will they just make it a copper composite like the other cheaper ones will offer.
              • #22
                If you have a good machine shops in your area they can machine your heads to accept a steel o-ring which can then be use in conjunction with a copper gasket. But honestly there are enough people making the power your are with and without boost and they do not have gasket problems. So if I were you I would be taking a second look at the head and deck surface, the assembly procedure and your tune.
                • #23
                  Yeps I have read that , but do you guys think maybe its the LIM gasket?? because as I was searchin online I saw that if you have a bad headgasket you should get white smoke or maybe the engine isn't working smooth.
                  Tomorrow I will do a compression test to see if all cylinders are ok.
                  • #24
                    Yes it could be the LIM. They are a much more common failure on the 3X00 motors and would explain the water and oil mix.
                    • #25
                      Yeah but why would his LIM fail if its obviously been replaced when he did the head gaskets.
                      What LIMG's are you using? Stock? plastic Fel Pro? Or PermaSeal Fel Pro metal ones?
                      • #26
                        if it is the LIM thats done for, i would say the first two would be the most likely, since i have yet to hear 1 complaint about the permaseals...
                        • #27
                          Hmm wel its a OEM headgasket kit I bought so bought at a GM dealer over here
                          • #28
                            there is the problem then. all i can say is.....for the most part, the gm gaskets (on the v6) leave alot to be desired
                            • #29
                              I say do a compression test, if it checks out then you didn't blow a headgasket but you blew your lower intake manifold gasket. Seems like it would be easy to do since people have so many issues with them leaking NOT under boost, you could blow them apart like crazy.
                              If that is the case you def want to go pickup the metal perma-seal set from Felpro and leave your headgaskets alone.
                              And I'd drop your boosted AFR just a bit even if your not knocking, for safety.
                              SpudFiles
                              Theopia
                              Enjoy life online.
                              • #30
                                Hey dudes well it's not the headgaskets. I made a compression test and all cylinder came up to 12 bar of pressure. So next I will make a coolant system pressure test.
                                For the LIM gaskets I never saw metal ones you know. Bought a while back a felpro upperkit and got the plastic one same as the OEM gasket set
