I know most guys don't pay much attention to engine weight but I'm hoping someone can help me out here. I'm new to the 660 so I won't have some specifics but here goes.
I was given a 91 2.8 (LL2-R) with a T5 out of a S-10. Complete was running and fairly low miles so just about perfect for my purpose. (The owner found out that staring fluid and fuel injection don't mix well.) That is putting it into a Locost or Stalker frame. That usually ends up about 1400 lbs by the time the dust settles. So to get more out of that I need to go with more power or lighter. If I can make the engine lighter it has plenty of power (for now)
I've been offered a Buick 3.1 don't know yet if it is G2 or 3. I've looked over the forums and from what I've found so far it looks like I have a few options. I do not have to be concerned about smog stuff and have a couple of megasquirts sitting on the self. So I'm inclined to use the HEI off of the 2.8 and the MS. I'm not too worried about intakes or exhausts at this point. I see there are some issues about the intakes matching up but I was planning on a mpfi controlled by the megasquirt using a custom manifold. Exhaust would be custom headers.
So I see two ways to use the 3.1. One is to hit it with a hammer until it runs in rwd configuration. I know about the starter and motor mount (not 100% sure about that one yet but looking still). I gather there a few things like making room for the hei to fit past manifolds? I assume it has the drive gear for it regardless. Or I could use the mega squirt and spark to do efi and ignition. Have I missed anything basic on that? One thing I haven't seen is if the 3.1 crank has the same flywheel bolt pattern as the rwd 2.8. I am assuming this is a manual/trans axle 3.1 not an auto box. But if it is an auto does it still work? I've been looking for a list of what I need from the car/engine but haven't seen a noob level list to know what to grab yet. This is sort of s sawp deal where he gets the bits I don't use on my or his engine (its a shop class engine)
Second option is to do the head swap. This seems a lot more straight forward to me. The only problem is the compression. Not being that familiar I wonder if there is enough meat in the head to open up the chamber enough to drop the compression down to where pump gas will work say 9.5-10.5 -1 Thick head gaskets? Used to do double gaskets on a few engines but have no idea if the gaskets design or the engine would let that work. It would be nice to do the heads without resorting to a rebuild to swap pistons.
So what other options do I have to get a lighter engine. And no I'm not going to buy the bow tie alum block (I'll wait for Santa) so I need to look at choosing the lightest combination of more or less stock parts. I would of course like to use that 3.1 as its free but am open to other options. If I can get 180-200hp with say efi, a cam and headers (mild mods) I'm more than happy. If I can drop the engine weight 50-60 lbs then it gets really interesting. Appreciate any and all info I can get.
Tnx!
Dave
Tnx!
Dave
