Hmmm. ran it through the compression calc, and it seems its 11.14:1. Not too bad.
A 3400 with 3.4L iron head pistons in comparision is 12.39:1.
EDIT, 2nd try.
3100 with 3.1 rwd pistons and .040 3.1 headgasket and 3400 28.6cc heads = 11.4:1 with .057 quench which isn't too far off the 3500 stock quench. Cool.
But this raises the question that according to the calc 3400 heads have a larger combustion chamber to keep the compression the same after the increase in bore. So that means if you put 3400 heads on a 3100 it lowers the compression to about 9:1...
Does that mean 2000+ 3100 heads have a different casting # than 3400 heads to keep the compression up???? What gives?
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
So is the calc wrong on the piston dish being the same for the 3100 and 3400 and the heads are the same or????
