Well call me a Hoosier, but I would rather eat my corn on the cob then run my car on it....
e85 turbo
Takes a lot of coal to make e85.... unless you are running nuclear or hydro/air power..
Dairy, eggs, etc have all gone up in price here because of the corn prices... Going towards e85 instead of livestock.sigpic New 2010 project (click image)
Originally posted by pocket-rocket View PostWell call me a Hoosier, but I would rather eat my corn on the cob then run my car on it....
Originally posted by IsaacHayes View PostTakes a lot of coal to make e85.... unless you are running nuclear or hydro/air power..
AaronGTR (boost lover).. do you believe everything you read? some sources are more credible than others. I'm sure you'll catch on.
scott0999- thanks for chiming in with some hands-on experience.. I was trying to find more info on the 660 and e85 but hadn't had any luck.
RedZMonte- I might be interested. shoot me a pm or an email with your price.88 Beretta GT
69 Corvette
79 Mustang Ghia
95 Cutlass Convertible
Originally posted by scott0999 View PostWTF does this have to do with E85? just some random political comment????
wow.
wow...-60v6's 2nd Jon M.
Originally posted by bbeck View PostAaronGTR (boost lover).. do you believe everything you read? some sources are more credible than others. I'm sure you'll catch on.
Credible sources? Are you serious? I'd be FAR more likely to believe what I read in a FACTORY SERVICE MANUAL for my car than listen to a bunch of douche bags from a forum for a totally different car. Sheesh.'97 Grand Prix GT 3800 (sold)
Gotta love boost!
In the thread linked by the OP to LS1 site it is stated quite clearly...
E85 requires 39% more fuel to reach stoich even if that is not what you may come up with when doing calculations based on the table below. This is because the injector flow is slightly different when using E85 among many other things I canīt really think of at this time (will be added at a later time).
And then at the end...
So let me tell you guys about the fuel prices here in Sweden.
98 octane gasoline cost 12sek/L = $1.68/L = $6.36/gallon.
And 104 octane E85 cost 8sek/L = $1.12/L = $4.24/gallon.
Even that my car wants more fuel with E85 i still save money.Last edited by carbon; 10-28-2009, 07:38 AM.sigpic
- Ben
It was stated years ago that due to the energy content a gallon of gasoline produces more miles than a gallon of ethanol in the same car. In other words you are effectively paying more per mile with ethanol tainted fuel. Given the nature of a capitalist society and the benefits to be had by the lobbyist due to the ignorance of our law makers about the subject and the way the stock market works under the influence of futures and derivatives, the true purpose of ethanol mixed fuel was probably long lost before it was put on the market.
If it were all it was cracked up to be you would think the EPA would not be as persistent as they are being with emmissions restrictions as the incorporation of ethanol would have made a big improvement right?
I imagine we all can gain some improvement with the new fuel over what stock specs can provide if we take advantage of the increased detonation resistance by increasing the compression ratio. Perhaps that has more to do with why the newer engines flex fuel or not are running higher static compression ratios instead of tech advances, because of the scarcity of pure gasoline.
I am all for this E85 in the 60degree running a forced induction.
burns cleaner than all petro
cheap race gas
Most of our cars can handle it already handle it with minor changes.
less dependency on foreign.
I run E85 in my 89 Turbo Voyager.
There will be other ways in future other than corn. Brazil uses cane sugar for instance.
This sure beats the old days of Tetra-ethyl which is truly unsafe.1990 6000 SE AWD 3.1 "The Goose"
1995 Beretta Z26
1996 Beretta Z25 w/3500
1999 GAGT
