Who wants flat tappet cams?
  • #16
    OK. I can base it off a 60-1
    I have ALL of Comp's lobes, flat, roller, solid flat, solid roller, and even their "secret" racing lobes (use at own risk lol).
    Once all your specs are in the sim, I can get the best results staying withing your max lift (which is?)
    • #17
      you can only get grinds that match our journal size.
      • #18
        Right. SBC journals.
        • #19
          my max would be .510 with a 1.6 rocker. i might be able to go more, when checked my clearances the valve didnt even touch the clay. and that was with .512 lift
          '86 Grand National
          • #20
            payment sent BTW
            '86 Grand National
            • #21
              payment sent BTW
              Cool.
              ot a kitchen to put in tomorrow, but between tonight and tomorrow, I should have some results for ya
              Oh yeah, intended RPM range helps
              What kind of gears/trans you running?
              • #22
                Cool.
                oh yeah, right 6000-6500K is my range. im happy with the 3.42 gears i have now, and the tranny is still up in the air. its between a Astro performance 5-speed and a well built 7004R. no rush man, ill be in town until monday. i have to go to south america with my unit the whole month of july so its no big deal
                '86 Grand National
                • #23
                  John:
                  What were the specs on the last chart you posted?
                  • #24
                    Originally posted by Lilchief View Post
                    John:
                    You will get a cam card in your box
                    J/K
                    int/exh - lift, adv dur, dur @ .050", ICL, LSA...
                    .494/.514, 269/294.2, 213.3/246.1, 108*, 110.5
                    61.4* overlap
                    • #25
                      34Blazer, don't know if I would trust this SIM for real life #'s, but if they are close, then I hope you strengthened your block o.0...
                      lilchief, here's the cam for your iron head Fiero...
                      • #26
                        Oh yeah. Ordered a cam for fleenor on July 3rd, got here last night (aprox. 18 days from order to delivery).
                        • #27
                          Sweet, I'll keep an eye out for it. Thanks again. Are you gonna do a thread on my wiring harness?
                          • #28
                            Yep, still working on it
                            • #29
                              Hopefully you guys will post videos as well, but here's a member from another board that has my ported heads (someone else's manis) and one of my cams.
                              He wanted lope, he got it - still not running right until he receives my obd1.5-obd1 swap kit, takes the engine several minutes to "learn" idle lol...
                              • #30
                                what are his cam specs? i love the slow lope. the 272 is pretty good.
                                Andy
                                fastest 1/8: 10.19@ 67.17
                                fastest 1/4: 16.16@ 82.70
