BillS: iron heads won't take as much boost as aluminium before knocking. And I'm not so sure a fuel cut on your motor when it starts to knock is a good idea under boost. That's a good way to start knocking more and melt pistons!
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
Lowering the CR for boost is old school thinking and is a thing of the past.
That all depends on the amount of boost you want to run. If he is at 10.5:1 compression, then I wouldn't recommend any thing over 5 lbs of boost on a street vehicle.
When the injectors shut down, you don't get a lean run condition (which would trash pistons) you get a no run condition - the fire goes out and doesn't come on again until you lift off. Wondered what the heck had happened first time I hit that, believe me! Miller Woods used that system and it seems to work just fine - not that you are bouncing of the limit all the time.
I'm willing to risk as high PSI as I can get as long as the tune is within a safe territory. There really is no magic number seeing how every engine takes on detonation differently.
new issue.. my engine bay is smaller than i thought.. i dont even think its possable to mount one where the AC goes.. took a few measurements to compare to different chargers
sigpic 88 Beretta CL- 13.641@102.76mph (rwd LS1/t56 conversion in progress)
Talk to mars_man and see if he can get you some pics of his setup.
