I have a 3400 sitting on my garage floor begging me to do something with it... I am curious which would be better for a forced induction application, the stock 3400 top end, possibly ported, or the 3500 top end?
I had read somewhere that the 3400 upper intake does a better job at getting equal flow all around where the 3500 upper, while flowing more, doesn't do as well at equal flow. Is it significant enough to be concerned or is there some benefit to using the 3500 other than flow?
Also, with the 3500 heads decreasing compression a little with stock 3400 pistons, I was thinking that using the heads and lower intake from the 3500 but with the 3400 upper would be the way to go... but I am just not sure.
Also what would be a recommended size turbo to use for a middle of the road build for say 250-275HP at the crank on a 3400? I am not interested in setting the world on fire but I would like more oomph than the stock 185HP.
One more question... is the stock cam O.K. for forced induction or is there a significantly better profile one for forced induction? This would most likely be a staged process with getting the 3400 running N/A first and then adding the turbo at a later date. But I would like to have the engine set up for that upgrade.
