I have a 95 3100 engine that I would like to swap a 97 3400 upper and lower intake manifold onto. I see the EGR is a little different, as I have the EGR that is in this picture:
I won't be getting a 00+ intake however, so this isn't the adapter I will need. I am assuming I will be needing this one, correct?
It says I also need "96 3100 EGR Flex Pipe (or complete rear manifold)." Where is the best place to buy this pipe as I don't believe I have it?
Also I read that I will need to clearance the rocker arms. How much machining needs to be done? Is this something simple enough to do yourself with a dremel tool or grinder?
And lastly is there anything else I will need to deal with? I plan on reusing all the 3100 fuel rail assembly and tb (for now).
