CAMs and stuff
  • CAMs and stuff
    Some of you know i have a Pontiac Phoenix LJ with a 2.8L v6 in it..
    i was wondering if some 1 here could help me find the right cam for me
    My engine is carbed so no computer tuning right?
    i want it to lope you know sound really cool were it can idel but not realy...
    im kinda lost on what i should get and were to even get a cam for a v6
    and when and if i do get a new cam i will get new bearings, hyd. lifters, pushrods, balls,aand rocker arms
    and would i use new stock rocker arms and just a new cam
    some 1 wana help a guy out lol
    thanks
    Get the Crane Cams 272 cam with Comp Magnum 1.6:1 roller tip rockers. No sense in buying new stock rocker arms when the magnum arm are under $150 for the set, are roller tip and higher ratio they come with new pivots and nuts also. The lifters will come with the cam kit and you don't really need new pushrods if your trying to same some cash.
    You wont be able to change the bearings with the engine in the car. It will have to be pulled.
    You will also need new valve springs, retainers and valve seals.
    Hell you know what after all this shopping you should just buy the comp Cams K kit. K16-233-4 it will give you the comp cams 260H cam and all the related parts you need to support the cam. Then you just have to buy the rockers on top of that. It wont have quite the lope of the Crane cam but will perform very nicely. Just lower the idle to get more lope LOL
      dude your cool thanks
      but if i do pull the motor witch i proble will knowing me can i replace the bearings
        i forgot to ask were would i get all this stuff is thear a web site some were
          If your using an automatic,you may might wanna stay conservative on the duration to avoid changing to a higher stall converter. Those 2.8s are sortta doggish anyway, so you don't wanna compound the issue any further
            hey if i only drove my car on the street once a month and it was like a strip car how big of a cam can i go with out no new pistons of what not
            here this will help
            1981 pontiac phoenix LJ
            2.8L v6 60 degree
            stock crankshaft
            stock coneting rods
            stock pistons stock heads
            stock hyd. lifters
            stock pushrods
            stock valve spings
            stock rocker arms
            So this is confusing
            for this Camshaft i want it to lope alot cus i like that sound and yeah i dont drive it alot this year im pulling it to a drag strip with my freinds stock 92 cav. with a 1988 2.8 its gunna be 1 cool race SO
            i just want a BIG CAMSHAFT
            i want it to open for a long time and sound cool lope ya know and but i dont want the valves to hit the pistions you know what im saying i want a big cam and all but i dont wanna buy new pistons
            AND sence like the valves are open longer will it fire and burn in the exhaust or how the heck dose the timeing end up right or will i have to set the Dis. cap forward or what lol srry i type to mutch i just wanna get this right
            so can some 1 help me find a place to buy or look at thease
              ah never mind i just what it to kinda lope and still be able to drive on the street
              so were can i buys this cam and stuff and get my moneys worth
                ok i think i found one
                http://store.summitracing.com/partde...4&autoview=sku <CLICK
                and http://store.summitracing.com/partde...2&autoview=sku <CLICK
                i think ill go with that
                  Summit is good but don't overlook your local suppliers. I get my parts CHEAPER than the American price on Summit's site and I am buying in CDN dollars.
                  Your engine does not have that high of compression unless it is the HO engine. So going with a large cam like the Crane 272 will hurt performance. I would stick with the Comp 260 package. Do you know if you have the HO engine?
                    i dont think so
                      If not then you have 8.5:1 compression which will not be good with a high performance cam. You want a cam that will help build cylinder pressure.
                        To get significant lope at idle, you'd have to install more cam than your engine can use unless you change a lot of other things. Catch 22, I'm afraid.
                        I use the 272 cam and it doesn't have much lope at all. Mind you I am using it on an injected 3.4 - I have no idea if the experience with a carbbed 2.8 would be any different.
                          That's the smartest bit of info I have read on this site since I joined! It's Refreshing to hear someone admit there not sure or just don't know...
                          Look kid sorry to tell you but you motor is down on luck.. your piston compression height is just too low (.020) and your valves a bit small to enjoy
                          a lopy cam....
                          Cheap fix: glass pack, advance timing 4-6* turn down the Idle to 750-800
                          and have fun!
                          Mild cost: Eldelbrock manifold, 350 or 390 Carb, with time adjustment and glass pack or Junk yard 86 or newer 2.8 - 3.1 - 3.4
                          Asking mom and dad for cash build: 3500, 3X00, efi, and so no and so forth, to many threads listing options we all wish we had time and money to build....umm
                          sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
                            Start with a 85+ block if you can. Those early ones are weaksauce in the bearing department. Mine started to let go at 150k. use a F body 3.1 or 3.4 block as alternative if you want to build all out. Are you sticking with that craptacular rochester electronic carb?
                            1990 6000 SE AWD 3.1 "The Goose"
                            1995 Beretta Z26
                            1996 Beretta Z25 w/3500
                            1999 GAGT
                              didn't all of the gen2 blocks have oiling issues/downfalls compared to a gen3?
