Accel Super Coil #140011
  • Accel Super Coil #140011
    Has anyone here used Accel's Super Coil model 140011? It's described as an identical, bolt-in replacement for the '84-95 external factory coil, but unfortunately the publicity photo doesn't show the connector configuration.
    I was looking for a replacement coil for my '84 Blazer (2.8L) awhile back and IIRC the coils I was finding had a slightly different connector layout and the factory plug wouldn't work. If someone here can accurately describe the 140011 connections or maybe even provide a photo it would be extremely helpful. Thanks!
    The other option is the universal-fit #140008 coil but it's about $15 more and would require minor wiring modifications.
    Brad
    That coil replaces all GM HEI remote mount two plug coils. If your truck has the two plug coil it will work. It is just like the MSD GM Blaster coil.
      Personally I've not had any luck with any accel products in the past 10 years and avoid them like the plague.
      87 3.4 4x4 blazer
