Okay so I have been in the process of rebuilding my lz9 thats going into my beretta. So far I have custom wiseco pistons(thermal coated tops), narrowed carillo h-beams, crank is being offset ground to fit rods(sbc big journal 2.100"), radiator fan is going to be upgraded to high flow type,arp head studs, main studs,and a double roller timing chain from TCE along with cam sleeves for gen 3 cam just to name a few mods to the engine. I am concerned with the power levels I am eventually going to push that the blocks integrity could be compromised. If this was just a v8 build I would get another block, but kinda stuck if I want to stay with the v6 platform. So I am going to be filling the block. First problem is there aren't any freeze plugs other than whats in the heads so I was planning to fill to the bottom of the block heater plug that is found on this block. This would amount to about 1.75" and the water jackets are just a tick over 5 inches. Now the other option is to fill to the bottom of the water pump holes on the block. This would be about 3.5" or so roughly, and leave 1.5" at the top of the cylinder walls to be cooled. Reason I am even considering filling that high is that this engine has piston squirters that will provide lots of oil cooling capability on the cylinder walls. I already have purchased a rather large 6 pass perma cool oil cooler(might need a t-stat so it can warm up), and will be adding a remote mount filter setup with dual wix 51522 filters. Along with running a full synthetic oil this should allow for good cooling overall.
Okay so now that I have given a brief overview(LOL), I would appreciate any constructive criticism. I've already talked to the machinest, and he doesn't think a short fill would be a concern other than checking coolant to make sure the filler isn't gunking up the water pump(leading to its death). Then I also checked around the net, and found various threads about guys having success with both short and tall fills on the street as long as cooling systems areup to snuff. I should also mention this will be mainly track use, and only short drives on the street on the weekends that may add up to less the 2000-3000 miles a year.
