what is an ideal compression ratio for a N/A motor, and who offers the pistons for that, and what are the other ways to accomplish the ratio.
I've read in posts that someone used camaro head gaskets, but I got confused as to if it was for a iron heads or not, do I want high compression 9:1? or 11:1?, what have some of you guys done to establish some good numbers? and who should I get what internals from, what pistons will hold up the best, and not cost 1000$
I'm starting to get fustraited with reading topics all the time, and not getting the answer I need, so i'm just going to ask, I want to get a cam for mid and high rpm power, possibly getting a no2 kit, wet or dry, I don't even know, I'm rebuilding a whole 3400 motor, and porting and polishing the heads, upper and lower intakes, and possibly getting the 3500 upper intake. are the pistons from summit reasonable for this kind of application? the motor will be going in a beretta with an auto trans and obdii wiring and proper tuning when everything gets to that stage, i'm willing to spend some money, but not dropping more than $2500 on just the motor and internals, i'm doing all the assembally and as much as I can myself with help. someone point me somewhere.
Just name it atleast and i'll source it. thanks.
Bob
Bob
