Can i use these injectors/ plugs
  • Can i use these injectors/ plugs
    My bird has the rwd 2.8, and i was wondering if these parts would work with my car?
    -Fuel injectors out of a 3400 #s- 2211c, c4b (would this make it run to rich?)
    -NGK Iridium plugs part # ITR4A15
    they will need different plugs on the injector harness. not sure about the plugs. any supporting mods to put that big of an injector in the engine? stockers are fine unless your boosting or spraying.. or a big cam with head work. as for the plugs, ppl on the site will agree when i say stick with AC Delco's!
    [SIGPIC]
    12.268@117... 11's to come!
      the ac delco iridium plugs are actually made by ngk.
      dont remember the part number off hand for the ac delcos but they are stamped NGK on the plug just rebadged for ac delco boxes.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        Dont really have any mods other than K&N cone and headers, only reason i was considering the injectors is my could probably use new ones also the 3400 ones have the tip that atomizes? the fuel better. I have the injector harness and i have been considering boosting the motor to the max then when it blows replace it with a 3.4
