my cam broke in half. I need to replace it but I don't want to gofactory so I need performance where can I find a cheap can?
cams
give these guys a call
service and price is A++#1 1989 RS - THE L98 AND LT1/LS1 KILLER
1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
#2 95 granprix 3100 all stock for now
ported heads and cam comming soon, megasquirt ems and turbo down the road
you can get a cam oput of the WOT-tech store here. they're around 330, but they're ground on solid cores, so there shouldn't ever be a worry of them breaking.
although, if your cam broke, i think you'll need more than just a cam. they do break, but not by themselves...... other stuff tends to happen first. LIMG leak sends coolant into the oil, then one of the cam bearings locks up, is how that story goes, IIRC....
Cammed 3400 --> 224whp 210wtq
Cammed 3500 --> ???
1 of 5 3500 J-Bodies
