I've seen his propane threads around here. Last I heard he was having problems getting it to work with the massive boost from the M90 SC. Pretty interesting project though.
3.4 carb and dist
Betterthanyou: I put it together from an astrovan. You gave me the idea from your posts. I got the courage to try it because I thought you actually put one on your s10 too. But I guess you didn't! It works really good.
I broke a ring land on the 2nd dyno run. Not enough ring end gap I figure. But I at least got to drive it for a few months last summer. 300 ft/lbs 300 hp.
Originally posted by ssdurango View PostBetterthanyou: I put it together from an astrovan. You gave me the idea from your posts. I got the courage to try it because I thought you actually put one on your s10 too. But I guess you didn't! It works really good.
I broke a ring land on the 2nd dyno run. Not enough ring end gap I figure. But I at least got to drive it for a few months last summer. 300 ft/lbs 300 hp.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
