Sooo...I have been really bored lately so I wanted to see if I could get some fresh air through the engine bay by removing the hood insulation and weatherstripping at the back of the hood (including the foam pieces in the corners).
Impressions; definitely more engine noise...not a problem if you like the sound. A little more wind noise at highway speeds.
After a 1 hour+ run up 95 today, everything under the hood was cool/cold to the touch except the exhaust pipes and coolant lines. The throttle body was luke-warm at the most (obviously because of the coolant that runs through it). The same on the run back at 4:30pm.
I still get airflow through the ducts at highway speeds with the fan off, so there is still high pressure there. I am just wondering which way the air is going...in or out from the base of the windshield, depending on if the windshield makes a higher pressure area than under the hood as the air flows through the radiator.
I am interested to see how it goes during the summer...and in the rain.
