what head gaskets are you using? i know the Camaro 3.4s were .040 and the bore is 3.75". that will change CR a tad.
Engine rebuild
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Originally posted by torq455 View Postwhat head gaskets are you using? i know the Camaro 3.4s were .040 and the bore is 3.75". that will change CR a tad.
so 3.1 with the rwd gasket and 3.1 with fwd gasket#1 1989 RS - THE L98 AND LT1/LS1 KILLER
1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
#2 95 granprix 3100 all stock for now
ported heads and cam comming soon, megasquirt ems and turbo down the road
yeah, but i didn't think either iron nor aluminum 3.1 had a head gasket available in a 0.040. only the iron head camaro with the 3.4.Andy
im pretty sure the iron head 2.8/3.1 has an .040 compressed gasket#1 1989 RS - THE L98 AND LT1/LS1 KILLER
Damn I would love to do it but I think the machining cost would be prohibitive. I will talk to the shop and see how much of a hassle machining the deck will be. I will also have the stock deck UT'd at work to see how thick it is. Does anyone know how much material can be removed from the deck or heads before the intake needs to be machined? If I do get this done then I will gasket match the intake to fix any port alignment problems that may arise.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Originally posted by betterthanyou View PostDamn I would love to do it but I think the machining cost would be prohibitive. I will talk to the shop and see how much of a hassle machining the deck will be. I will also have the stock deck UT'd at work to see how thick it is. Does anyone know how much material can be removed from the deck or heads before the intake needs to be machined? If I do get this done then I will gasket match the intake to fix any port alignment problems that may arise.
my recommendation if u do this is to use stock/factory pistons, there is no guarantee that an aftermarket pistion will have the same thickness crown
but if u do have diff pistons it is easy to measure and see , ill see if i cant borrow a camaera and take some pics on how to do it#1 1989 RS - THE L98 AND LT1/LS1 KILLER
Franz ( XLR8ING) had the deck machined so the pistons would be at zero deck. i don't believe he had to machine/port match his intake.Andy
Originally posted by project89 View Postur not machining the deck, u machine the tops of the 2.8 pistons, any machine shop should do this cheap.
but if u do have diff pistons it is easy to measure and see , ill see if i cant borrow a camaera and take some pics on how to do it1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
people do it all the time. you are worrying too much again. machining isnt $$$ at all. you dont machine a dish, you just cut the top off. even machining a dish, you put it in a lathe and cut. not hard at all. any machine shop worth its salt could do it.
of course cutting the heads/deck isnt much either
I'll ask but I am sure it would be a lot more. Plus they are going to have to calculate the amount of dish I will need in order to get the compression I want. I cannot go with a flat top piston on a 3.1L or the compression will be too high for me. So I will need a dish. It would be nice to get a spherical dish in the piston like the LS series pistons. It is reported they make good power and burn well.
Plus if .193 is left after machining 4mm off a 2.8L pistons whats going to be left if you add an additional dish into the piston. Its starting to sound a little thin to me.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
umm sorry, most LS pistons are flat top. almost all dish pistons are spherical....just like the 3400 pistons stock. if the LS piston has any CC under 10...its just 2 valve reliefs, otherwise they are flat
stock LS pistons are flycut .080. then hit with a huge cam....meaning 240dur +++ and nitrous 100+++.
No most dish pistons are a cut dish with flat bottoms. The spherical ones look like a ball was pressed into the top of the piston to make the dish.
Although what you get depends on the compression you want.Last edited by geoffinbc; 02-01-2009, 10:39 PM.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
oh hah....no ls piston is like that.
trust me i know, i work with LS pistons ALL DAY. the forged are either flat top, dished like a 3400, big valve reliefs, or a huge dome. those are hard to find...but you can still cut something like that on a lathe.
they flycut them big for high comp, big cam and spray. the most i have seen them flycut is .090, most do .080 just for clearance on a big cam. they use 58cc heads to bring comp up to 12:1 or higher and still run a big hit of nitrous
Well you haven't seen them all then because that is a stock GM LS9 pistonA couple guys on this years engine masters challenge have taken this design and report it makes great power and burns very evenly
