they bore the block in order to use the torrington bearings in place of the OEM bearings. there was an article that showed the process. nice idea, and they are primarily used for racing. this is the type of bearing i'm referring to: http://www.daltonbearing.com/Torring...r-Bearings.asp they had to remove a lot of material. i don't know if there is enough material to allow to bearing the cam journals in the 660.
Max cam lobe lift
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Originally posted by torq455 View Postthey bore the block in order to use the torrington bearings in place of the OEM bearings. there was an article that showed the process. nice idea, and they are primarily used for racing. this is the type of bearing i'm referring to: http://www.daltonbearing.com/Torring...r-Bearings.asp they had to remove a lot of material. i don't know if there is enough material to allow to bearing the cam journals in the 660.Lifting my front wheels, one jack at a time.
yeah. you also don't need to have forced oiling either. they block the oil holes as they only require splash lubrication. they didn't mention how much it cost. wonder why....Andy
Originally posted by sprucegagt View PostThis mod may be worth something if the cost to HP improvement ratio wasn't so bad. Don't look for a big HP increase with this mod. In fact I would be surprised if you got more than 5 HP out of it.
HP gains would all depend on cam profile, open/closed valve spring load etc.. for someone turning 7K+ RPM with 300+lbs open spring pressure they would deffenetly help. The oil film buildup in regular bearings is probably pretty thin at that point.
yah, id rather go with a napier ring or something cuz they arent much more $$$ and will help gain HP and sealing ability....without further machining or a custom tool to install them. and that would be on a high perf engine, not just a 7k race rod
a quick google search notes claims of 2-15 HP.. Most have said that they use them with extreme valve spring pressures, 400+.
I guess it's just one of those things that is neat but not really needed.. kinda like powdercoating the lifter valley.
well good. money saved. besides, i wonder if something like that will stand up to many thousands of miles anyway. imagine if a bearing goes...Andy
I thought this subject had a familiar ring to it.
http://60degreev6.com/forum/f98/comp...e-is-it-t40786Your local OBDII moderator
2000 Grand Am GT w/ WOT parts
