any1 have a megasquirt file for a tgp?
  • any1 have a megasquirt file for a tgp?
    if i decide/have to go megasquirt, does anyone here have a megasquirt file for their tgp that they could share with me-i dont need a really kickass one,i just need one that will make my car run-i can modify it from there-i just dont know what values i need to input into it to get my engine to idle-if i could get there then i would happily go megasquirt. any help would be GREATLY appreciated!!
    getting the car to idle is the simplest thing to do.
    if u read threw the megamanual it gives u step by step instructions on how to do it
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
      how can it give you instructions on how to do it if you could be using it on anything from a 4-8 cylinder?
