As it turns out I like building frankenstien engines and when my 3400/3500 hybrid is done I'll have a ton of parts lying around. I'm looking at building another frankenstien engine but I don't know if any of this stuff will work together.
The idea is I want a short stroke high revving, high compression gen 3. At my disposal I have a 00+ 3400 top end. I have or will have soon a 00+ 3100 bottom end, a 3.1 bottom end and a 2.8 bottom end.
What combination of parts that i already have can I use to make a 2.8L Gen 3 engine with nothing higher than 11.5:1 CR??
Am I better off with just slapping the 3400 top end on the 2.8 gen 2 bottom end?? If this is anything like a 3X00 top end on a 3.1 and logically to me it should be then this combo will be 9.X:1 compression?? I'd prefer the gen 3 block but whatever gets it done reliably for the least money will win here.
The 2.8 bottom end interests me because performance cams are pretty inexpensive but if the full g3 2.8 can work I guess I could also do a regrind. If I do this it will be on an extreme tight budget so a WOT cam is not really an option (that's for my 3400/3500 motor)
So assuming that i either stick with a stock cam or something not too crazy what size tb should I be using?? I've got a nice little 62mm FDP here but if a stock 3X00 cam will be enough then so be it..
I'm thinking 7000 rpm should be the highest this thing revs. I'd do the lt1/ls1 lifter mod and i guess some ls6 valve springs.
I'm looking for something like 175 crank hp and he same for tq, if i can hit 200 well all the better but no more than that.
This will never get headers so gen 3 manifolds and 2.5" exhaust recycled form my other car.
In the end I guess if all else fails I can put the 3.1 pistons in the 3100 and have a high compression 3100 with a reground cam but the 2.8L displacement interests me so I'd like to continue.
As mentioned earlier this is only a a possibility. I'm just trying to figure out what is necessary and what I already have that I shouldn't sell or what i can trade for what i need.
Thanks..
Oh and I did search but I didn't find what I needed..
Thanks..
