Since my trans is going bad and I'm going to pull it and rebuild it, I figured, while I'm there I'll just pull the motor too.
It's going to be March 1st till I can get my GP into my parents shop to tear into it....
SO, in the meantime, I want to build a motor and go OBDII so I can tune.
What I want out of the motor is to be lightly modded, nothing crazy.....maybe around ~230-240 Crank HP.
what ways will I achieve this from a 3400 ro 3500?......a 3400 is MUCH easier for me to get....so what parts off a 3500 can/should I swap on?
I will obviously do
-P&P the U/L intakes.....heads only if i can get instructions on where to do it for the best airflow
-springs
-mild Cam (what should I use?)
-Headers
-Tune (isn't a big problem because a local gen2 GP guys has a cracked HP tuner that can do ALL 97-03 PCM's IIRC
btw, I'm just getting a whole different motor because my 94 3100 has NON roller rocker heads and 126k miles.....and well, I want roller rockers and a lower mile motor to build.
any educated input into this would be awesome. My dad said he would help me do this since he knows how to install cams, pistons.....all hardware etc. And I understand (for the most part) all the FI side of it. I DON'T know much about the hardware installation side. So, what he and I do/don't know will make a complete combo.....LOL
How do I convert to OBDII?
I will obviously do
-springs
-Headers
