need 3500 rocker arm studs
  • #16
    If that was the real reason then it would need squirters on all cylinders, not just 5&6. What I'm trying to get at here is GM discovered a cooling problem with this engine in just those cylinders. The squirter is their cheapest/easiest fix for it. Removing it without any other cooling system mods may be asking for trouble. I understand that you need more oil volume. I'm just wondering if you thought about what would happen if you remove that squirter.
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
    • #17
      I've ran mine to ~7100 on the dyno with no float...
      I run Royal Purple 15w40
      • #18
        thats prob. why it doesnt float. that and u did mod the lifters.
        [SIGPIC]
        12.268@117... 11's to come!
        • #19
          What kind of modding can be done to the lifters?
          • #20
            I just told you on the phone
            EDIT: http://60degreev6.com/forum/f96/lift...841/post366863
            • #21
              Hydraulic lifters work to 7000 RPM as lorenzo has proven on the dyno. Valve float would equal power loss, and there was none.
              Redline is the best oil now?
              they work a lil past that actually ive seen 7,800 rpms unintentionally (mis set the shift light) with no sign of valve float.
              though i do purposely take it to 7,4-7,500 without issues
              the valve springs are 125 #'s seat and iirc just over 35x open at .550 or .600
              #1 1989 RS - THE L98 AND LT1/LS1 KILLER
              1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
              #2 95 granprix 3100 all stock for now
              ported heads and cam comming soon, megasquirt ems and turbo down the road
              • #22
                7500 will be an absolute redline for this motor. I dont intend to shift any higher than 7200 (which should fit the torque/power curve of my cam grind beautifully).
                Im running 122# comp-cams springs on stock 3500 valves w/ .523 max lift intake and exhaust. Im using Crower cromoly steel Rollr-rockers and hardened push-rods.
                The vote seems unanimous that I can get away with this on hydro lifters. Does anyone have any high-rpm dyno read-outs that I can glance at? If its do-"able", then Id rather run hydro tappets.
                P.S. Forced_Firebird spoke briefly about it, but how does one modify a roller hydro tappet for high rpms.?
