If I decide to use the 3500 exhaust manifolds........it seems that everyone wants to use two fronts. The only problem i see with the rear is that it needs a block off plate for the egr. My main question is that the 3400 uses one O2 and the 3500 uses 2. The 3400 has a second one but its behind the CAT and useless for fuel calculations. Would you somehow combine the 2 3500 O2s or eliminate 1 and block off 1 and if so would you use the rear bank for the true O2 as the 3400 set up does for fuel calculations......just a thought
Thanks
Thanks
>plan on sandblasting porting and having them coated as well.
