motor&car help
  • motor&car help
    i have a 88 Z24 that i am thinking of doing a drag racing car with if i can't sell by fall's end .
    i have a 3400 swap done i would like to boost it up a little bit to make it more fun but not make myself broke .(as i have another car to do that LOL)
    i had bought a msd ignition system and a nitrous kit for it and had pland a 4 spd auto swap.
    but anyways i left it 5spd is anyone running nitrous with a stick ? and how is it ?
    the intakes i have are a 99 style do the 00+ intakes flow much beter ?
    i plan on geting some 3500 mani's to do a set of dual's
    is there some other little tricks i can do to get a little bit more out of my combo ?
    thanks guys
    00 and up manifolds are the best. Why would you want to make it auto? Stick with the 5 speed.
      i hate a 5spd for the street that's why i wanted to do the auto swap
        3.4L/205 Cu.In.
        Sequentially Fuel Injected
        Normally Aspirated
        SAE Net Horsepower 180 @ 5200
        SAE Net Torque 205 lb ft @ 4000 RPM
        are these numbers right ? look alittle on the low side !
          does anybody have the stock specs on the 3400 cam ???
              thanks brad !
                iwas reading info on the 3400 intake manifolds and it is said that the 00+ are better then the 96-99 but all motors from all years rated the same ? is this just GM not changing there ratings or does this diffrent casting only make a diffrence if you compleatly port them ?
                  All 3400 manifolds are the same.
                  '00+ 3100 manifolds are the same as 3400 manifolds.
                  96-99 3100 manifolds are worse.
