What is the highest CR I can acheive with a 3500 top...3400 bottom and stock forged pistons.......what head gasket combo will give me the highest possible CR....?
Factory parts and a 3400 head gasket will net 9.15:1 IIRC... Iron head gaskets will raise it but also lessen your clearance from the piston top to the cylinder head, so only 3400 head gaskets are recommended for the 3400 bottom ends.
Uhm, as high as you want with custom pistons... LOL.
If you have a rowdy cam then 11.5:1 is ok for pump gas. But with boost, that throws another factor in.
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
3400 bottom end with stock spec pistions and stock combustion chamber 3500 head, you are looking at about 9.10:1 ~ 9.20:1 CR
2000 Grand Am GT 2011 Chevy Impala
THnaKS
Chris
He didn't say how high can I get the compression with a 3400 block and 3500 top end and "Custom Pistons" he stated that he has stock form forged pistons, so the highest is 9.20:1 and thats getting lucky.
Out of all honesty a 3400/3500 hybrid is a Boost build to start with factory specs, but yes with higher compression (custom pistons) you will get more power n/a.
Not according to the CR calculator. I used all the 3400 specs including headgasket since I'm using a 3400 headgasket and my cylinder heads are stock, so I assume they are the measured CC's minus a minimal amount since I had them surfaced... But this is what it comes up with just the CC's changed for the heads.
Your CR will be what i posted above if your using all stock dimension parts, forged or not. Now if you use a piston that says it will be 10.2:1 on a 3400 to get a general guess on the CR you can take the 9.5 vs 9.16:1 difference and subtract that from the 10.2 but if you know the new piston dish size the go to the cr checker on this site use all the numbers I did above but sub in your new piston dish or difference in bore dia an run the calculation.
I guess.......I just want to make sure that the pistons I bought are going to give me the highest compression for boost thats best for my application. I am confused....if the other pistons are better......then I will buy them...if mine will work as well...then I will use them.............??????
stock rods or SBC rods, they shouldn't affect the compression ratio.....
I know that.....what I was referring to was the pin size.........are the piston pins sized for stock rods or SBC rods...the small end is different.................
