Finally finished
  • #76
    picture with the valves in the head and a port pic? otherwise i have plenty of port pictures.. ceramic coating could be a possibility, im havin my turbine done at scotts, so i could swing over there..
    [SIGPIC]
    12.268@117... 11's to come!
    • #77
      i would totally coat the chambers and exh. ports. hell, i've heard you can buy some stuff to do it yourself, if i can find it and it looks worth it, i'm totally doing it. and it'd be totally more worth it for you, keeping as much heat as possible inside the motor/pipes/turbo will give you the best setup possible(i know you already know this)
      Cammed 3400 --> 224whp 210wtq
      Cammed 3500 --> ???
      1 of 5 3500 J-Bodies
      • #78
        i'd coat the pistons too. i wouldn't do it myself. i'm too afraid of the coating flaking off!
        Andy
        fastest 1/8: 10.19@ 67.17
        fastest 1/4: 16.16@ 82.70
        • #79
          im not too worried about coatings as of yet... plus putting a coating on myself i would worry about having hot spots in uneven places.
          [SIGPIC]
          • #80
            well i got the engine in finally... i went over to the house at 2pm with 2 cases of beer and a couple buddies, got the heads on, sat and drank alot..then at 6 we kinda figured we should get to the real reason why we were there: put the engine in! i put it in with no intakes though, i didnt have my lifters done yet..i got those put together tonight. tomorrow at work im going to tap out the intake coolant pipe hole to fit my 3 wire coolant temp sensor. then put the lower intake on, and start on my new trans mount (makin room for the turbo).
            me enjoying a beer after gettin the engine in..
            [SIGPIC]
            • #81
              Originally posted by RedBird View Post
              hey paul any chance you can get a weight comparision on that PS pump pulley VS the stock one? and is there any difference in diameter?
              sry i couldnt find a scale anywhere, but the metal pulley feels slightly lighter than the plastic, as for a measurement i can get that, kinda forgot.
              [SIGPIC]
              • #82
                techline makes some good coatings that would work for pistons and headers, turbo/etc etc etc ... look into them.
                • #83
                  Not sure if it was posted before but where did you get the ps pump pulley?
                  • #84
                    Good luck with those LS6 springs..
                    your IH will be taller though, that might help.
                    • #85
                      its off of the vvt 3500's. looks so much better and more durable then the shitty plastic. yeah we will see about the springs... i kinda bought them be4 i chose the stage 4 cam instead of the stage 3. but the install height should help a little.. if i gotta change them i have the tool to pump up some air in the cylinders.
                      [SIGPIC]
                      • #86
                        It does look good. My plastic one lasted about 160-170k before it cracked. Nothing $15 didn't solve though. lol
                        • #87
                          hey have you been able to do that mount for me i havent heard back from u on v6z24 yet but this looks like suttn i may want to do on my 3400 swap
                          • #88
                            totally forgot that was on v6. ive gotta locate some steel quickly first.
                            [SIGPIC]
                            • #89
                              Paul, do you have a part number for that pully? Mine is cracked and this would be a nice upgrade..
                              • #90
                                Yeah x2 on the part #. If mine cracks ever again I'd rather put this nice unit on. I take it fits just the same? Hey Dave, does yours sound supercharger with that cracked pulley? Mine did... lol
