found this on GAGT.com looks interesting.
found this carb conversion any good?
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
Tags: None
thats what i was thinking certainly would be easier than screwing with the ecu.
my guess is he prob had in an older hot rod or something. just by looking at it you would most likely end up cutting a hole in the hood.
pretty sick get up none the less and for the 100 bucks either way it couldnt be a bad buy.sigpic
99 Grand Am GT
yeah i would really like to go carbed on my set up but i don't want to go back to the iron heads and i would also like for it to be tucked under the hood is possible because anybody can weld a carb flanged to the top of a 3500 manifold and have it sticking out of the hood LOL01 olds shilluette 3400/4T65-E stock for now
That is the second time the setup has been for sale.
A 600 cfm carb seems like overkill on one of these engine.....2000 Grand Am GT
2011 Chevy Impala
wow, what a quick way to lose power, driveability, tuneability, gas mileage and part of your hood... those of you who think it's easier to tune a carb obviously have never done it.
Fuel injection is MUCH more accurate in every way, Leave the carbs on the 70's cars where they belong.
Originally posted by Superdave View Postwow, what a quick way to lose power, driveability, tuneability, gas mileage and part of your hood... those of you who think it's easier to tune a carb obviously have never done it.
Fuel injection is MUCH more accurate in every way, Leave the carbs on the 70's cars where they belong.2000 Grand Am GT
2011 Chevy Impala
Yea the SFI manifolds have too much plenum for a Carb. Drivability would be the shits. Full throttle and high Rpm might be ok though.
Although the initial cost of tuning your EFI system is higher once you have the means to do it you will not have to spend another dime. You can do it as often as you like without even opening your hood. I guarantee anyone who can tune a carb can learn EFI tuning basics in a day and in a week they will be well versed in the subject. I bet it would take ten times longer to do the same if you were learning to tune a carb for the first time. Plus EFI gives you feedback unlike a carb. Of course you could put a wideband O2 sensor on your carb setup to get feedback, but if you go that far you may as well go all the way1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
