i thought they were 1.6.
3.9L LZ9 engine internal upgrade & performance?
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
when i think about it...that sounds familiar.Andy
Hey everyone. Started another quarter. Well, here's the latest developments (issues).
I am going to try to fit the LS1 valves into the heads. This in turn will means I have more than likely have to replace the valve seats. And also widen/unshroud the combustion chamber around the intake valve, especially on the outer edge of the chamber.
Also, discovered that the current LS1 pistons will work for four of the six cylinders. Due to the fact that the other two cylinders have the intake and exhaust places swapped. So, we're going to have to cut the reliefs by hand (not literally, but you know what I mean) onto the non-cut side of the pistons (since I have to match all). But that will have to wait until I have the valve fitting resolved.
Originally posted by SappySE107 View PostWhy are you going to use LS1 valves?
Originally posted by Joseph Upson View PostWould like to see more pictures instead of words though.
Originally posted by SappySE107 View PostI have not found any benefit to larger valves in any of the splayed 60V6 heads I have done research on. The 3900 may be different, but I wouldn't hold my breath on it.
Desktop Dyno shows greater benefit for an increase in exhaust valve diameter than intake. It's not a necessity but I want to make the engine perform maximally without having to rely so heavily on high boost.
Originally posted by SappySE107 View PostInteresting fact, the 3400 and 3900 have the exact same exhaust port runner, with the bowl opened up to accomodate the larger valve.
When you don't gain flow with larger valves, I don't know how boosted vs NA is going to change that fact.
We may disagree on this but a larger valve than stock in a system that flows considerably more air than stock should make a difference provided the rest of the path is addressed. I'd have to ignore some common laws of physics to accept otherwise.
If the stock size is more than sufficient for natural aspiration then I agree a larger valve is not going to help much if at all if there is no additional flow to justify the additional area. Just keeping in touch with the production trend, larger engine getting larger valves.
Just in case I misunderstood what you were saying, my rational is I'm moving 5.7L or greater exhaust volume so I should be able to benefit from 5.7L valve size with the additional equivalents in port volume.
