Yes they designed some rockers for the 3900 as well. They are close but not compatible.
3.9L LZ9 engine internal upgrade & performance?
Interesting that your block was not painted on that one side, its all rusty!sigpicNew 2010 project (click image)
My manual confirms a stock deck height of 8.818. The wierd thing is this manual also says rod length is 5.9", but after talking with pauter rods who measured my stocker they gave me a measurement of 5.827 center to center. Hopefully the rest of the specs are all good to go by. No word on wall thickness yet. If anyone needs any other specs listed I will be happy to share.98 camaro swapping in lz9 th400 setup
LZ9 specs: (Subject to Change work in progress)
4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
I'm willing to bet your manual will list the exact same specs we already have on the site (see post #12 for link).-Brad-
Originally posted by Nightingale View PostMy manual confirms a stock deck height of 8.818. The wierd thing is this manual also says rod length is 5.9", but after talking with pauter rods who measured my stocker they gave me a measurement of 5.827 center to center. Hopefully the rest of the specs are all good to go by. No word on wall thickness yet. If anyone needs any other specs listed I will be happy to share.
I will page through tomorrow and try to get some scans, but ya I did read the specs page. I was weary about trusting the specs page as I didn't know the source. Either way the Helms manual is extremely helpful. Also I don't believe it lists weights just clearences and tolerances, dissassembly/assembly instructions, diagnostics, etc. It includes everything for the g6. I was a little surprised to find 3 telephone book sized manuals in the box weighing around 15lbs lol. I knew there'd be a lot of info just not that much heh.98 camaro swapping in lz9 th400 setup
Hey Nightingale, what the PN for the paper manual. And how much was it if I may ask? Is there a CD/DVD version available? I would like to get the manual myself and start reading up on it. I need to figure out how I'm gonna run this motor after I'm done with it.Last edited by mrtohil; 10-01-2008, 07:31 PM.
I knew the weights wouldn't be in the manual, I thought you had parts at the machine shop that can be weighed.
The Helms manuals aren't cheap, and probably cost ~$ 135, years ago they went fromt about $45 to more than double that I discovered on attempting to order a Fiero manual a few months after having ordered one for my camaro.
Electronics wise it should have some valuable info on the VVT module and that would be good to have.
You can search the HELMS company on line for the manuals, I'm sure you won't be interested in the $400 CD sets.
I measured one of my rods today. It ended up being 5.925in, which is pretty close to the 5.9in advertised in the spec sheet.
I don't think the school has a scale intended for this. I'll find out. If it ends up too much of a hassle I might as well get a small electronic one of my own.
Well, this weekend I'll have to dedicate on knocking on everyone's door who makes rods and find out how much for some forged rods. Let the Benjamins start flying out my wallet!
I would just shave the crank rod journals and use sbc rods. All said and done it'd be cheaper then custom. Pauter quoted me around 1200 for a set of rods, but they are pretty much indestructable. I am probably gonna go with eagle 3d rods with l19 rod bolt upgrade. It will give me a slight bump in displacement (like 3.9l to 4.0L lol), but I still want to keep the rod/stroke ratio good and keep up revability versus just going for max displacement. I know I can pick up more stroke from going to the small journal sbc rod vs the big journal rod, but not sure how much it'd affect the integrity of the crank if at all.98 camaro swapping in lz9 th400 setup
Originally posted by mrtohil View PostI measured one of my rods today. It ended up being 5.925in, which is pretty close to the 5.9in advertised in the spec sheet.
A small block chevy rod is the best route to take except in an extreme build. That is what was done with the old 2.8L for increased strength. For the cost of custom rods you can buy a set of forged chevy rods good to at least 600 hp or more and have the crank welded if necessary and offset ground. The pistons have offset pins if I recall correctly to help reduce side thrust loads so going with a 5.7" rod shouldn't cost you any sacrifice especially with todays metallurgy and design. The LS1 pistons also have offset pins which is another plus for them being used in the 3900.
