I am going to be doing a 3100 topend swap on my Turbo 3.1. I want to do a cam swap but don't really want to go big at all. I want something just a little bit better than the stock cam, so I have pretty much decided on the Powermax 2030 with 1.6 roller rockers. I was thinking of just going with the 260, but I want pretty close to equal valve lift, and I don't want to run different ratio rockers on the intake & exhaust, and I don't think I want a cam that big, even though it is fairly small. I want something that sounds stock and isn't going to require computer work to make the car run. So I will just make a list of what I will be doing when the engine is torn apart, and if you guys could give suggestions of what you would do, and let me know of things that i missed or won't work that would be great.
I will be doing:
Powermax 2030 Camshaft & Lifters
Comp Cams 1.6:1 Roller Tip Rocker Arms (assuming they work, I have been told they might not)
Comp Cams Pushrods (just so I'm not re-using the stock ones)
'95 3100 Topend Swap
Ported Exhaust Manifolds
And possible a TopGun 160 chip at the same time, but not sure yet.
So, what I am asking is, what do you think? Do you see anything that isn't going to work? What would you do in my case?
Also, what kind of power increase do you think I will see?
Thanks,
Shawn
I will be doing:
Thanks,
Shawn
