Yeah one reason why I never have put an UDP on is that my motor has a ton of miles, and I'm sure the crank bearings don't look so hot. I don't want to give it an excuse to spin one (or do I? new motor! yeah! lol). With a high HP motor as yours I would be running a dampener. A stock one will probably last a while, but you need the protection with the extra forces you are generating and the extra RPMs.
Just my luck...
Originally posted by siKKa View PostI heard a tip from a guy that used to build race engines. Put a touch of LocTite on the backsides of the bearings, being sure not to plug the oil feel holes. He says you'll never spin a bearing again...
I have a 3400 and am planning on a helluva build over the winter to drop in the corsica. if i dont end up going to B.C
I run a stock dampner on my motor and the one I ran the FFP UDP on I just found out has a lunched timing chain set... I wonder if thats related... No issues bearing wise tho.
Originally posted by gectek View Postim sorry did you read the rest of the thread...already mentionedLast edited by siKKa; 09-15-2008, 07:01 PM.1994 Cavalier Z24, 5 speed swap, 3500 LX9 (summer ride)
1998 Lumina LS, (SS) L67 3800 S/C swap (winter ride)
1999 Honda CBR600 F4, 600cc DOHC I4, cammed.
I asked the machine shop about the Loctite and they laughed..
either way, the crank is with them now being turned 10/10. He confirmed without a doubt that the 7484 crank is forged steel, also confirned by other people in the lobby of the shop.
turnaround time could be a week or more.. hopefully less.
well yah just like alot of machine shops around here havent heard of chamfering valve springs...they may laugh, but i know diesel shops that do it all the time when they have problem childs like that. why dont those bearings look like they go with those rods...they have the notches for 2 tangs on the bearings? why dont the bearings have the tangs? also did you look at ur rockers and see if they were missing any rollers or the side covers...that would be a major issue worth checking out, unless that isnt ur pic that the guy earlier posted
I have always been told that you shouldn't use anything between the bearings and rod/block as it acts as an insulator and reduces heat transfer. Maybe an old myth... don't know.
The dangers of a solid UDP has been debated here many times. They scare me... that's why I have never made any.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
maybe thats why that FFP UDP spent its life sitting on my desk until i sold it.
i never got around to putting it on and im glad i never used it. sold it for what i paid for it.sigpic
99 Grand Am GT
I never claimed the grammar was as good as the read :P lol-60v6's 2nd Jon M.
Dave I also have a crank pulley you could use, it's actually the one from the 3500 (where is your original)? Granted I believe that the 3500's was a bit larger, it may be a bit lighter? I don't have both to compare but I am fairly sure they were a bit different...SpudFiles
Theopia
Enjoy life online.
